sminnick
Cancel Uninstall, process doesn't end, won't uninstall after
After installing on windows 7 x64. Go to uninstall. The first window that pops up is "are you sure you want to uninstall?". You select NO. That window closes. Then if you go to uninstall it again, you get the attached window.
Please wait until the current program is finished uninstalling or being changed. I noticed that the process is still running, the setup exe process. If I kill it, or reboot it goes away and lets me uninstall. Reproducible on multiple win 7 x64 machines.
I was trying to get a log file for the uninstall problem. When I run from the command window:
C:\>msiexec /x {F9FDF6AA-4E32-45D7-959E-7967EB570B5A} /L*V "C:\logfile.log"
This does NOT occur.
In order to reproduce you need to use the programs and features of windows and click on the application and click uninstall, and cancel from there. And then do it again, through the windows gui. If you do it via command line it doesn't happen.
Re: Cancel Uninstall, process doesn't end, won't uninstall a
Indeed, this is an Advanced Installer issue which we are aware of. A fix was already included in the newest version of Advanced Installer that should be released very soon. Sorry for the inconvenience.
sminnick
Do you have an ETA when this newest version of Advanced Installer will be made available?
Unfortunately I cannot be sure when this version will be available, but we hope to get it ready by the end of this week or during the next week.
This was fixed in version 11.5 of Advanced Installer released on September 25th, 2014.
hariram
Re: Cancel Uninstall, process doesn't end, won't uninstall after
Open task manager--> Kill explorer.exe under processes tab (by right click and end process) --> switch to Applications in the same window --> click new task --> enter "explorer" --> press enter key.
Now go again to the uninstall program and it works as usual.
Its working, I had the same issue and tried this way. IT WORKS !!! :D
