predatorxxx
Need help with project
Hello! I need help with my project.
My project contains following items:
1) installing sql server 2008 , if user check it in dialog forms
2) installing .NET 4.0 , if it not exist on pc.
3) execution of SQL queries (database creation, login, create tables). Requests are processed on a specified server, or one that was created in claim 1.
4) unpacking required components by specified path
5) Replacing some of the values ​​in a pair of text documents (xml).
with claim 4 no problem - I have added all files with “Files and Folders”.
question: how to install sql server only if user click that he wants to install it. Or if he wants to use how own sql server - he must type it in appropriate dialog form. how to configure route. see scheme.png
question 2: how to check connection with sql server with button on dialog form? see scheme.png
Thank you for attention! Regards, Stanislav.
Re: Need help with project
The sample project is attached to this thread, so if you are interested to take a look directly at my project, you are more than welcome to download the ZIP file.
Select the [ Check Connection ] button from this dialog and go to the Published Events tab and add a new "Set installer property value" Published Event with the parameters described in the How to test SQL connection parameters article.
UI_SQL designSample.zip
(5.17 KiB) Downloaded 210 times
