Jaradat
SQL express 2008 r2 with advanced services
When installing (SQL express 2008 r2 with advanced services) in command line using CMD it works and installed successfully, but when using Advanced installer to install it in silent mode it gives the following error
Command line (silent mode)
SQLEXPRADV_x86_ENU.exe /INSTANCEID="SQLEXPRESS_1" /ACTION="Install" /FEATURES=SQLENGINE,REPLICATION,FULLTEXT,RS,BIDS,SSMS,SNAC_SDK,OCS /HELP="False" /INDICATEPROGRESS="False" /QUIETSIMPLE="False" /X86="False" /ROLE="AllFeatures_WithDefaults" /ENU="True" /ERRORREPORTING="False" /IAcceptSQLServerLicenseTerms="True" /INSTANCEDIR="C:\Program Files\Microsoft SQL Server" /SQMREPORTING="False" /INSTANCENAME="SQLEXPRESS_1" /AGTSVCACCOUNT="NT AUTHORITY\SYSTEM" /AGTSVCSTARTUPTYPE="Disabled" /ISSVCSTARTUPTYPE="Automatic" /ISSVCACCOUNT="NT AUTHORITY\NetworkService" /ASSVCSTARTUPTYPE="Automatic" /ASCOLLATION="Latin1_General_CI_AS" /ASDATADIR="Data" /ASLOGDIR="Log" /ASBACKUPDIR="Backup" /ASTEMPDIR="Temp" /ASCONFIGDIR="Config" /ASPROVIDERMSOLAP="1" /FARMADMINPORT="0" /SQLSVCSTARTUPTYPE="Automatic" /FILESTREAMLEVEL="0" /ENABLERANU="True" /SQLCOLLATION="SQL_Latin1_General_CP1_CI_AS" /SQLSVCACCOUNT="NT AUTHORITY\SYSTEM" /SQLSYSADMINACCOUNTS="BUILTIN\ADMINISTRATORS" /SECURITYMODE="SQL" /ADDCURRENTUSERASSQLADMIN="True" /TCPENABLED="1" /NPENABLED="0" /BROWSERSVCSTARTUPTYPE="Automatic" /RSSVCACCOUNT="NT AUTHORITY\NETWORK SERVICE" /RSSVCSTARTUPTYPE="Automatic" /RSINSTALLMODE="FilesOnlyMode" /SAPWD="smartA"
plz any body tell me the reason of that error :)
error SQL.png (80.43 KiB) Viewed 4745 times
Re: SQL express 2008 r2 with advanced services
In order to install silent the SQL Server, you can use the /Q parameter.
So, can you please add the following command line parameters in the Install Command Lines field from the Setup Files tab of the prerequisite and see if the behavior still persist?
/q /INSTANCEID="SQLEXPRESS_1" /ACTION="Install" /FEATURES=SQLENGINE,REPLICATION,FULLTEXT,RS,BIDS,SSMS,SNAC_SDK,OCS /HELP="False" /INDICATEPROGRESS="False" /QUIETSIMPLE="False" /X86="False" /ROLE="AllFeatures_WithDefaults" /ENU="True" /ERRORREPORTING="False" /IAcceptSQLServerLicenseTerms="True" /INSTANCEDIR="C:\Program Files\Microsoft SQL Server" /SQMREPORTING="False" /INSTANCENAME="SQLEXPRESS_1" /AGTSVCACCOUNT="NT AUTHORITY\SYSTEM" /AGTSVCSTARTUPTYPE="Disabled" /ISSVCSTARTUPTYPE="Automatic" /ISSVCACCOUNT="NT AUTHORITY\NetworkService" /ASSVCSTARTUPTYPE="Automatic" /ASCOLLATION="Latin1_General_CI_AS" /ASDATADIR="Data" /ASLOGDIR="Log" /ASBACKUPDIR="Backup" /ASTEMPDIR="Temp" /ASCONFIGDIR="Config" /ASPROVIDERMSOLAP="1" /FARMADMINPORT="0" /SQLSVCSTARTUPTYPE="Automatic" /FILESTREAMLEVEL="0" /ENABLERANU="True" /SQLCOLLATION="SQL_Latin1_General_CP1_CI_AS" /SQLSVCACCOUNT="NT AUTHORITY\SYSTEM" /SQLSYSADMINACCOUNTS="BUILTIN\ADMINISTRATORS" /SECURITYMODE="SQL" /ADDCURRENTUSERASSQLADMIN="True" /TCPENABLED="1" /NPENABLED="0" /BROWSERSVCSTARTUPTYPE="Automatic" /RSSVCACCOUNT="NT AUTHORITY\NETWORK SERVICE" /RSSVCSTARTUPTYPE="Automatic" /RSINSTALLMODE="FilesOnlyMode" /SAPWD="smartA"
You can also take a look on the SQL FAQ which may be useful to you.
Jaradat
Unfortunately it never worked with me .
