minnumathew
Tlb file not removed during uninstall
Hi
My installer is registering a tlb file using Type libraries under COM. Never overwrite option is added for this file and the file is getting properly registered. My issue is that this file is not getting removed during uninstall. Please advice me.
mihai.petcu
Re: Tlb file not removed during uninstall
Maybe the file gets modified somehow after installation. Whatever the case may be adding an uninstall File Removal operation for it from the Files and Folders page should fix the issue.
