WesCutting
Testing SQL Parameters
My question is in reference to the following help page: http://www.advancedinstaller.com/user-g ... ction.html
I am currently operating with Advanced Installer 10.9.1 and am attempting to verify the user defined SQL information before I allow them to precede. Unfortunately the information in the help page above does not line up with what your software is displaying to me. For whatever reason SQLConnectionOK does not get set to 1 and therefore won't allow the user to progress if the information is valid (I know it is valid because without the test the information I enter works during the install). This roadblock raises several questions, the primary few being:
Why is the support documentation different from your software?
Does my version of AI not match your documentation (am I out of date or are your docs out of date)?
Are all the fields in the SQLConnectionString required to test the ODBC connection? For example if the user is using Windows Authentication to connect to their server a standard connection string will not have the Username or Password fields
Re: Testing SQL Parameters
Indeed, the image with the Test ODBC connection custom actions properties from the Test SQL Connection article hadn't been updated to the new UI. We will update our User Guide ASAP. Thank you for bringing it to our attention.
So, when you are asked to add the Test ODBC Connection custom action just add it in the Custom Actions page and then proceed forward with the other steps, the workflow has not been changed.
