vidur
Web Deploy Fails
Im trying to create an installer which uses a web deply .zip package. I have used the web deploy feature under IIS settings , but when i run the installer on my server (server has web deploy installed) i get this error.
IIS Web Deploy Publish execution log:
Error 4033. An error has occurred during the IIS Web Deploy configuration process for package "MYSERVER".
Do you want to skip this package and continue the installation ?
MSI (s) (A8!90) [18:39:18:768]: Product: MYSERVER-- Error 4033. An error has occurred during the IIS Web Deploy configuration process for package "MYSERVER".
Any ideas?
mihai.petcu
Re: Web Deploy Fails
Can you please generate a verbose log so we can take a look at what's going on? Send us the project file (.AIP) to support at advancedinstaller dot com as well, maybe we can find something particular.
vidur
Im still facing issues trying to install a web application using web deploy. Here is my aip and attached is webdeply compressed file. Please Help.
22.zip
Compresed webdeploy file
(2.65 KiB) Downloaded 425 times
SERVERTEST.aip
WebDeply test aip file
(12.66 KiB) Downloaded 444 times
We have tested your scenario and we discovered an Advanced Installer issue. It seems the web deployment fails due to the file name of your web deploy package. When the web deploy package file name starts with a digit, then the web deployment fails. This is an Advanced Installer issue and a fix will be available in our next version of Advanced Installer (11.6). Thank you for bringing this to our attention.
Until then, as a workaround you should just rename your web deployment package to a name which starts with a letter (e.g. MyApp.zip) and delete and re-addd it on our "IIS" page.
vidur
Hi Daniel,
Thanks for your reply. As advised by you, i changed the name of my web deployment zip to "MyApp.zp" , But i face the same issue. I have attached the new .aip file and the renamed .zip file along with the verbose log .
Could this be a web deploy version issue. ?
Thanks for you help,
Vidur Sharma
servertestinstall.log
Verbose Log
(250.01 KiB) Downloaded 677 times
MyApp.zip
Deployment zip file
(2.65 KiB) Downloaded 616 times
SERVERTEST.aip
Web deply test aip file
(12.68 KiB) Downloaded 530 times
Hello Vidur,
The Advanced Installer feature for publishing web deploy packages requires Microsoft Web Deploy 3.5 and PowerShell 2.0 (or later) to be installed on the target machine where the main installation runs. So, can you please make sure on target machine is installed Microsoft Web Deploy 3.5 service and PowerShell 2.0 (or later) ?
Let us know if this helped.
vidur
The target machine has web deploy 3.5 and power shell 2.0 installed on it. But the installation still fails with the same error?
Does the attached aip work on your side?
Hello Vidur,
I've tested your attached project on a Windows 8 and Windows Vista machine, but the installation succeeded. In order to investigate further this issue, can you download this attached debug DLL, replace the original one from the install folder of Advanced Installer 11.4.1 (e.g. "C:\Program Files (x86)\Caphyon\Advanced Installer 11.4.1\custact\x86\iis.dll"), rebuild the package and test again the installation?
This DLL should create a debug log (at install time) on the root of the OS partition (e.g. C:\AI_IIS.log), which can give us more details about the problem. Please send us the "AI_IIS.log" created during your failing installation so we can investigate it.
vidur
Thanks for your answeres. Its seems to be working now, i had re install my web deploy and the problem fixed iteslf
You're welcome. I'm glad you sorted this out.
