vidur
Using temporary files in custom action
I have recently updated my advanced installer to the latest one 11.4.1. And used it to build my project .
When i ran the setup file, it failed at a part where i use a temporary file in a custom action. When i checked my project file, i noticed at the custom action part the action data is underlined in red and says identifier not found
*This worked perfectly fine on the previous version, has something changed?
Scenario
file : Windows Value\Temporary\testfile.exe
Table data
FileID:testfile.exe
Proprty:AI_TESTFILE.EXE
Custom action:
action data : [&testfile.exe]
Addition
Log:
Executing op: ActionStart(Name=ManageExplorer,,)
MSI (s) (9C:BC) [10:25:45:347]: Executing op: CustomActionSchedule(Action=ManageExplorer,ActionType=3073,Source=BinaryData,Target=CreateExeProcess,)
MSI (s) (9C:A0) [10:25:45:367]: Invoking remote custom action. DLL: C:\Windows\Installer\MSIDD80.tmp, Entrypoint: CreateExeProcess
MSI (s) (9C:94) [10:25:45:367]: Generating random cookie.
MSI (s) (9C:94) [10:25:45:377]: Created Custom Action Server with PID 8604 (0x219C).
MSI (s) (9C:3C) [10:25:45:407]: Running as a service.
MSI (s) (9C:3C) [10:25:45:407]: Hello, I'm your 32bit Elevated custom action server.
CustomAction ManageExplorer returned actual error code 1603 (note this may not be 100% accurate if translation happened inside sandbox)
Action ended 10:25:45: InstallExecute. Return value 3.
What am i doing wrong here?
Re: Using temporary files in custom action
I'm not sure why you encountered the this behavior.
vidur
I have sent the aip file along with log to your mentioned email. Still waiting for a reply.
andy way i have also uploaded the test aip here which fails as well. along with the log. Can you please tell me whats wrong?
TempFilecustomactionFailed.LOG
Failure log
(470.04 KiB) Downloaded 287 times
Your Application.aip
AIP files
(12.36 KiB) Downloaded 349 times
Hi Vidur,
Can you please enable the Run under the LocalSystem account with full privideges (no impersonation) option from the custom actions properties and see if the behavior still persist?
