mschindler
Host Name (Website Binding) as parameter
I'd like to define the "Host Name" (IIS -> Sites -> Bindings) as "Install Parameter". Problem here is, that "empty" parameters in Advanced Installer are not allowed. But I need to leave this field empty, if no host name is specified (see "(not specified)" in image below).
Is there a workaround?
Re: Host Name (Website Binding) as parameter
You can define the property in the Install Parameters page, and then reset its value (use {} for a null value) in the Custom Actions page using the predefined Set installer property custom action(make sure you add the custom action as a custom action with sequence).
The custom actions properties, can be something like that:
  • Property field: MY_PROP
  • Value field: {}
mschindler
It's not nice, but it works. Thanks.
mschindler
I ran into another problem:
If I place the custom action after Wizard Dialog State "Path resolution", this works fine in GUI mode, but not in silent mode (msiexec ... /qn) from command line.
If I place the custom action later, the value from the GUI dialog or from command line parameter gets overridden.
Is there a general solution for GUI and unattended setups?
When you run a package in silent mode it only executes the actions found in the "Install Execution Stage" and the custom actions found in "Wizard Dialog Stage" are not executed.
However, you can go in the Custom Actions page, press the SHIFT keyboard button, drag and drop your custom actions (duplicate) in the "Install Execution Stage", click on the "Advanced execution scenarios" link and check the "Skip action in Install Execution Stage if executed in Dialogs Stage" radio button.
In this case your custom actions will be executed in the "Install Execution Stage" only if they were not executed in the "Wizard Dialogs Stage".
mschindler
But the second custom action overrides the value from the command line parameters.
msiexec.exe /i "C:\Example.msi" SERVICEHOSTNAME="myValue" /qn
In my case, the SERVICEHOSTNAME will be "" instead of "myValue".
In order to overcome this, you can condition the execution of the custom action which set the property with the null value.
e.g. Add in the condition field
SERVICEHOSTNAME="DefaultValue"
where DefaultValue is the property's value defined in the InstallParameters page.
This way, the custom action will only be executed when the property has the default value.
mschindler
That's my current solution, but it's not really "clean".
Why doesn't Advanced Installer allow empty values for parameters? This workaround with two custom actions, a condition, ... etc. means a lot of work for the developer. And our company's software team has lots of web installers to deploy.
Please note that is not mandatory to define the property in the Install Parameters page.
You can use a property inside the Website Binding information without defining it before using. If the property is not set when you launch your installation package, it will be resolved at a null value, and this way you don't have to use the custom action to reset its value.
If you want to set its value, then you can use the usual command line and the property will be set accordingly.
Please let me know if this is working as expected.
mschindler
Thanks! That's a much better solution.
You're welcome,
