peter01242
Basic UI prevents app launch on exit
I am using the Free Version of Advanced Installer and have a small problem.
I am using the basic UI (progress and error handling) to minimise the impact on the target computer.
I want the installer to launch the program I am installing when it finishes but the basic UI mode seems to miss this step.
Any suggestions?
Thanks in advance,
Pete Young
Re: Basic UI prevents app launch on exit
Hi Pete and welcome to Advanced Installer forums.
The application is launched only when the "Finish" button is pressed on the "ExitDialog" dialog. But when a package is installed with Basic UI, only a progress dialog is displayed and, indeed, the application cannot be launched using the support from the "ExitDialog" dialog.
This can be achieved only through a custom action, but I'm afraid that the "Custom Actions" feature is available only in a "Professional" or higher project type.
peter01242
Thanks for the quick reply.
If I run the msi package via a command line with the -qr (reduced UI) parameter all the dialogs/progress windows display but no UI is needed; the installer completes; and the application launches on exit.
This should be sufficient for my requirements for now.
You're welcome Pete. I'm glad that scenario suits your requirements.
Just let us know anytime you have a question.
