ofendt
.NET Custom Action in VB
Is there a VB Hello Wold Custom Action.
I tried to make one - but it does not work - i get an error..
Imports System.ComponentModel
Imports System.Configuration.Install
Public Class CustomActions
<CustomAction()> _
Public Shared Function CustomAction1(ByVal session As Session) As ActionResult
'session.Log("Begin CustomAction1")
MsgBox("BBasic 123")
'Dim fr As New Form1
'fr.ShowDialog()
Return ActionResult.Success
End Function
End Class
I get ERROR 1001 String length may not be 0
Re: .NET Custom Action in VB
I'm not sure why you encountered the this behavior.
In order to have a better view about this, can you please send us the .AIP (project file) and the verbose log of the installation process to support at advancedinstaller dot com so we can investigate it? If it contains confidential information you can send us a small test project which reproduce this behavior.
