renejdm
Why can't I create patches with the professional version
I purchased the professional version of Advanced Installer. I was led to believe from your website that the professional version can install patches. So how do I create patches with the professional version? When I try to follow the tutorial and create a patch, I get a dialog saying that patches only work with the Enterprise version, which is too expensive for me.
Please tell me I am mistaken. I would never have purchased your product if I cannot create patches. My solution is 80 MB. Making small fixes would require someone to download the entire 80 MB.
Rene
Re: Why can't I create patches with the professional version
Hi Rene,
I'm not sure why you was led to believe that the "Patches" feature is included in the "Professional" version of Advanced Installer, but I'm afraid that as mentioned on the "Features list" page, this feature is included only in the "Enterprise" and "Architect" versions.
You can create "unconventional" patches using the "Professional" version, but the disadvantage is that the modified information is not registered with Windows Installer. This method is described on the Patch to replace 2 files thread.
renejdm
Here is why I was led to believe that patches can be made with the professional version. See attached screenshot.
So this makes your product useless to me for anything but first time installation. I will have to purchase another solution to handle patches and upgrades.
Disappointed!
Hi Rene,
That statement refers to the "Auto Updater" feature which "downloads and installs patches and updates" that are already created. The updater is meant only to download and install them, not to create them.
renejdm
It is misleading. I am sure you can agree. I want you to remove the "install patches" from the professional feature page so other people like myself are not mislead.
Sincerely,
Rene
Hi Rene,
Thank you. We will consider better clarifying the text that you mentioned.
However, as I already mentioned, the "Auto Updater" is a feature that can download and install packages and patches that are already created. They can be created using Advanced Installer or any other installer authoring tool.
For example, the patches can be created using the MsiMsp.exe SDK's tool as described in the Generating a Patch Package article.
renejdm
Thanks for your reply and for updating your features page for clarity.
I will consider using another tool for patches although I do not see how the automatic updater can include patches as the project updates the Updates.txt file to be placed on a server and this is how updates work with your product. Do you have to create the Updates.txt manually in this scenario? Or what?
Rene
Hi Rene,
You do not need to create the "updates.txt" file manually, you can generate it from an "Updates Configuration" project as described in the Creating a New Updates File tutorial. This feature is included in the "Professional" version.
Just that you will replace the "story2.0.msi" package from that tutorial with your "patch.msp" package.
renejdm
Okay. Thanks Eusebiu. I will give it a try.
Rene
You're welcome Rene. Just let us know anytime you need help.
