hhelbig
Surface theme without license agreement
I'm using AI Enterprise and like to use one of Surface themes.
Although 'Display License Agreement dialog' at 'Bootstrapper UI' is not checked and EULA path is empty, resulting setup is requiring acceptance of licence!
How to get this setup running without asking for license acceptance?
Re: Surface theme without license agreement
In order to achieve this, you can go in the "Dialogs" page and remove the following controls:
- "You must agree..." text control from the "WelcomeDlg" dialog
- "I agree to the..." checkbox from the same dialog
- select the "Install" button and remove the "NOT AGREE_CHECKBOX" and "AGREE_CHECKBOX" from the "Control Conditions" tab
- remove the "LicenseAgreementDlg" dialog
I underlined them in the attached image.
Lecense Agreement Surface.png (131.95 KiB) Viewed 6726 times
hhelbig
Great, it works!
One hint: I was not able to remove the "You must agree..." text control before removing the "LicenseAgreementDlg" dialog.
Thanks a lot!
You're welcome. Glad to help.
Indeed, the "LicenseAgreementDlg" dialog should be removed first.
rosiew
I cannot do this with my version. I have a professional version. Do you not allow changes for pro? Or is it the v12.2.1 of the software that is prohibiting me from turning off EULA
Hi and welcome to Advanced Installer forum.
I'm afraid that our "Dialog Editor" feature is available only in an " Enterprise" or higher project type and these changes cannot be done with a "Professional" version of Advanced Installer.
