Alex99
Upgrade failure removes old installation
I use AdvancedInstaller v.11.2.1. I have next uprades page:
On updrading if installation of new version fails installation of new version rollbacks, but deinstallation of old version wasn't rollback. Is there any AdvancedInstaller's way to restore old installation if new installtion fail or I have to customize upgrade behaviour manualy? And if I have to customize what information in registry I have to save before upgrade(to restore it after installation failure)?
Alex99
Re: Upgrade failure removes old installation
Also in order by: http://www.advancedinstaller.com/user-g ... rades.html I can't use "Install new version first and then uninstall old version" because every version components changes.
This is the normal Windows Installer behavior when using the "Uninstall old version first and then install new version" upgrade order. In case of an upgrade installation failure (after the "RemoveExistingProducts" standard action) the old product version installation won't be reverted on rollback.
In order to achieve what you want you can only use the "Install new version first and then uninstall old version" upgrade order which, as you already mentioned, implies some strict rules to be fulfilled (i.e. the files' components don't change from the old version to the new one, their names and GUIDs remain the same). Please take a look on our "Windows Installer Upgrades" article.
