hasic
Modify process works incorrect
Hi!
First of all - very impressive software, thank you. Use 11.5 version.
Dear developers, it seems that in my installer the feature "Modify" does not work correct.
The problem description.
I have made for instance 2 features in the intallation file.
Both features use folders:
feature 1:
-audio
-gui
feature 2:
-audio
-gui
-scripts/client/mods
-scripts/item_defs/vehicles/common
If user installs both of the features at once - there are no any problems.
If user installs just the 2nd feature - there are no any problems.
If user installs just a 1st feature, then goes to the installation file ->chooses "Modify" -> chooses 2nd feature - THERE IS A PROBLEM. The isntallation file does not install files from folder "SCRIPTS"! Files from "Audio" and "Gui" folders are installed proper.
There is a problem just with the folder "Scripts".
I've tripple checked all the folders - they DO have all the settings THE SAME! I have no idea why the installer does not "want" to install files from SCRIPTS folder during MODIFYING process.
Please help me with this issue!!! Hope my description is understandible).
Re: Modify process works incorrect
Thank you for your kinds words to Advanced Installer.
In order to have a better view about this, can you please send us the .AIP (project file) and a verbose log to support at advancedinstaller dot com so we can investigate them? If it contains confidential information you can send us a small test project which reproduce this behavior.
hasic
Hi, Dan!
Thanks for quick reply.
I had done the project from scratch and I do not know what exactly I had done - but the problem disappeared.
I think there was something wrong in installation files settings before.
Thank you!
You're welcome,
I'm glad you got this working. If there is anything else I can help you with, please let me know.
