coderbrat
How to place war file in webapps folder after tomcat install
I have included tomcat.exe as a prerequisite and it installs fine. After the prerequisite is done, I should be able to search for the installation folder and then place the war file in the folder and also set an environment variable.
I have followed the instructions in this post:
http://www.advancedinstaller.com/forums ... =5&t=27971
I added a search for tomcat installation, added a property based folder to the files and folder area with the search result as path. When I run the set up, it fails because it is not able to get the property based directory as tomcat hasnt been installed yet and hence no directory present.
How do I ensure that the placing of war file happens after prerequisites are installed?
Please advice.
Thanks.
Re: How to place war file in webapps folder after tomcat ins
In order to achieve what yo want you should make sure you have added the Tomcat prerequisite as a pre-install prerequisites. In this way the TOMCAT prerequisite will be installed before the MSI installation (when the searches from "Search" page are executed at the very beginning of the MSI installation during "AppSearch" standard action).
coderbrat
Thanks, Daniel.
Initially I had the prerequistes under Feature based. I just changed it to pre-install and I still have the same problem with search. Screenshot of my prerequisite is attached.
1. What am I doing wrong? Is there something I should do in custom action section?
2. Is there a way to do a silent install of Tomcat when I provide the .exe for tomcat installation? That way I can avoid searching and install in a specific directory.
Note: I am using the java project template and not the Tomcat template (I do not have an Enterprise licence)
Tomcat prerequisite screenshot
tomcat prerequisite.png (340.11 KiB) Viewed 2986 times
I'm not sure why the search fails. Can you please send us the .AIP (project file) and a verbose log of the installation to support at advancedinstaller dot com so we can investigate them?
Also, in order to silently install your Tomcat prerequisite you can add silent command line parameters in the "Prerequisites Setup Files tab -> Install Command Lines section -> Full UI field".
