ml123
Problems with Hebrew text
I'm trying to translate the texts to Hebrew via creating a new dictionary, and I'm facing some problems:
1. When assigning the Hebrew language, the wizard becomes RTL, which is good. Problem is, the top image, which has the "Advanced Installer" writing on it, also becomes RTL, and therefore appears mirrored (see attachment). How can I switch it back?
2. When setting the product name to be a Hebrew name, the name no longer appears in the wizard, but rather - the "Property.ProductName" appears instead (again, see attachment)
3. While writing the dictionary, I've imported it to test the changes. After that, I couldn't import newer versions of the dictionary, and I also cannot remove it from the list (the Remove button is greyed out). How can I update the dictionary?
Thanks!
Re: Problems with Hebrew text
Indeed, when an RTL language is used, the wizard automatically becomes RTL. The "Advanced Installer" text is inserted in the background image and when that image is flipped, the text is flipped, too.
The workaround is to have an image without that text then go in the "Themes" page, "Images" tab and replace the <AI_THEME_VAR>three-colors.jpg image (you can simply remove the text from the original image found at the "C:\Program Files (x86)\Caphyon\Advanced Installer 11.5\themes\modern\resources\variations\default\three-colors.jpg" location).
This happens because the Hebrew language is not yet translated in Advanced Installer. However, you can follow the steps below:
- go in the "Product Details" page, right-click on the "Product name" field, select "Localization...", check the "Always translate this string -> Using specified localization identifier" option and click OK
- go in the "Translations" page, "Project Strings" tab, double-click on the "Property.ProductName" row, on the "Hebrew" column and write the Hebrew product name there
I'm not sure why it cannot be removed from the list, however you do not need to remove it from the project. After you modify the dictionary, you can just reopen the AIP file and the modifications will be updated.
ml123
Thanks for the answers.
I still have problems, though...
Re 1: I don't see "Images" tab, I have only "Preview" and "Settings" tabs (attached a screenshot). Am I missing something?
Re 3: I'm not sure I understand what you mean by "reopen" the file. How do I open it? There are only "Add" and "Remove" buttons (and Remove is greyed...). Do you mean opening it in external tool? Because that didn't have any effect. I'm attaching a screenshot to demonstrate the current situation.
Thanks!
The "Images" tab is available only in the "Enterprise" or higher edition of Advanced Installer. However, you can still modify that image by replacing it at the following location:
I meant to reopen the AIP file, not the dictionary file. After you make some changes to the dictionary, you can just reopen the AIP file and the changes will be updated in the project.
The dictionary can be found at the following path and open in any text editor:
C:\ProgramData\Caphyon\Advanced Installer\dictionaries
However, all the updates can be easily don in the "Project Strings" and "Default Strings" tabs and saved using the "Save changes in a dictionary from repository" blue link.
ml123
As usual, top-notch support... :)
Thanks! That really helped, and I can now fully localize the installer.
You're welcome. Glad to help.
Just let us know anytime you have a question.
ml123
OK, I have another question...
I've set a "CompanyLogo" image for the Modern theme.
Problem is, in the Hebrew version of the Installer, the image appears flipped.
I need to display the same image in both the English & Hebrew versions.
How can that be done?
Thanks!
I'm afraid that this is the normal behavior. However, you can achieve what you want if you create two separate builds for the English and Hebrew languages. Just go in the "Media" page and add a new EXE build, then go in the "Translations" page, select each build from the toolbar and select a different language for them.
Create two logo images, one normal and one flipped. Then go in the "Themes" page, select each build and use the normal logo for the English build and the flipped logo for the Hebrew build. Also, go in the "Settings" tab, select each build and check the "Always" option for the "Enhanced User Interface" feature.
