aeplengg
Application prompt UAC message for standard user
I have a setup that is configured for "Per-machine only (fails if user is not administrator)" and "Run as administrator" installation type.
I install this setup on W8 64-bit with administrator login. Application runs ok with administrative privileges. But if i try to run an application for Standard user, it prompts message for password.
Is it possible to run application with standard user without prompting UAC message.
Swati
Re: Application prompt UAC message for standard user
Hi Swati,
Please keep in mind that this is the normal behavior. An application that requires administrator rights cannot be installed on a standard user without entering an administrator password.
Yes, you can achieve this by going in the "Install Parameters" page and selecting the "Per user-only" or "Per-machine if user is administrator, per-user otherwise" installations type. However, please make sure that you do not make, in your project, any configuration that requires administrator rights.
You can take a look on the Default for InstallTypeDlg in mixed per-machine/user setup thread which debates a similar problem.
