Alex99
Security message after finish
Hello. When I run installer I see windows security message
and it is ok. I press 'Run' and instaler starts. On ExitDialog when I click 'Finish' starts my Custom Action. After it ExitDialog closes. But after some time (5 - 10 seconds) Security Warning appears again. When I press 'Run' or 'Cancel' message disapperas. After some time (5 - 10 sceonds) this Warning appears again 3rd time. In task manager I see that after I press 'Finish' Installer processes was stoped and created serveral times. On some machines it happens silently on some it causes Security Warnings. What can be reason of this behaviour of installer(creating several processes after installation is finished)? How can I prevent this behaviour?
Re: Security message after finish
Hi Alex,
You get this message because you run your package from an unsafe location (i.e network) and it's not digitally signed. The prompt is a normal behavior. You will get this prompt even after you sign you package but then the Publisher will be known.
Also, you may receive the "Open File - Security Warning" during "ProgressDlg" if your setup package contains an URL-based prerequisite package. After clicking on [Install] button from "VerifyReadyDlg" dialog, our "Prerequisite" support tries to download the prerequisite package from the specified URL. If the URL is from an untrusted site the Internet security warning will be displayed.
Please take a look on the SmartScreen Filter: Installing an Application Using IE9 forum thread which debates a similar subject.
Alex99
Thank you, it is clear. But why installer processes starts after installation? It may confuse user asking to start installer when installation was ended. More strange that message appears only after upgrade. After simple installation installer's processes starts but without messages. May it be my fault and reason is I start CustomAction on 'Finish' button?(I don't start another installer's process in CustomAction). But from another hand I start this CustomAction in both install and upgrade scenarios. May be it some feature of how upgrade process ends?
Alex99
Found solution. It happens after I updated AdvancedInstaller to version 11.2.1. To solve problem I'll revert to 11.1 version.
