sonu
IE Tab Addon generation from installer
HI Support,
I Would like to install the IE Tab add-on to the Mozilla & Chrome Web browsers from an installer
For that can you guide me the best way of approach.
From my end I found a "ie_tab-4.0.20130422-fx-windows.xpi" file to set the IE tab for Mozilla browser.
Where as to Set IE Tab add-on for Chrome its provides Wensite base enable process.
Wit Regards,
Pradeep.
Re: IE Tab Addon generation from installer
Hi Pradeep,
Using the -install -extension <path_to_extension> command line options you should be able to install the extension for the Mozilla Firefox.
In order to achieve this functionality within Advanced Installer, you can add the .XPI file in the Files and Folders view. Then, in the Custom Actions page, you can add the predefined Launch file custom action as a custom action with sequence.
Edit the custom actions properties like this:
  • File to Launch: [ProgramFilesFolder]\Mozilla Firefox\firefox.exe
    Command Line: -install -extension "[#myExt.xpi]"
Please let me know if you have other questions.
sonu
HI Team,
Thnks for your reply I have gone through the command and executed its giving a POP saying that
[img]C:\Users\vgopisetty\Desktop\xtra.png[/img]
can i able to execute the total process Silent with out user interaction.
NEXT
Please help out on IE TAB addon IN Chrome Browser ?
Looking for you reply ASAP.
Pradeep.
Screen attachment for reference
Hi Pradeep,
Indeed, using the above approach, this is the normal behavior, as it is the same as you would drag the .XPI file over mozila firefox.exe.
Please take a look on the how do you install Firefox xpi plugin programmatically thread where is debated this subject. Also, you can search over the internet how you can install the related plugins programmatically.
