ifoko
detect uninstall
I want to make a custom aciton when a setup is uninstalled only. (Call .exe with parameter for webservice )
NOT when it is upgraded and so the old vesion is uninstalled when the new version is installed.
How can I differnt between explicit uninstall and uninstall due update ?
regards
Re: detect uninstall
Please note that you can use the Show upgrade options link from the Custom Action Properties to display the First Time Install, Upgrade, Regular uninstall and Replaced by a new version options options for the execution stage condition.
You should have something like that:
ifoko
thx, works
best regards
You're welcome,
