dhaval0129
Advanced Installer is not able to install MS VC++ 2013
Hi
I am trying to install Microsoft VC++ redistributable 2013 using advanced installer as prerequisite in silent mode, but it fails on Windows 8.1 Pro
I am attaching the screen shot and .aip file , I am using Advanced Installer 11.4.1 version
Please let me know how can I resolve the issue.
Dhaval Joshi
ClarityPACS-Integrated.zip
project aip file
(253.36 KiB) Downloaded 349 times
error screen shot
error screen shot
Re: Advanced Installer is not able to install MS VC++ 2013
Hi Dhaval,
I looked over your project and I noticed that the install condition that you set for the "VC++ 2013" prerequisite is not correct. In this case, the prerequisite is installed, but when it searches for the registry entry set in your install condition, it is not found and that error message is displayed.
You can use our predefined "VC++ 2013" prerequisite which has a correct install condition as displayed in the attached image. Also, please note that you should use the "Use 64-bit locations when evaluating conditions on a 64-bit machine" option for the "x64" prerequisites.
VC++ 2013 Condition.png (24.77 KiB) Viewed 4081 times
dhaval0129
its working, Thanks !!
