litu
System store certificates
I have a certificate for the code of my company. I've installed this certificate on every place I can think of in the Certificate management console.
The problem is when I choose the option "Use a certificate from system store" I can't see any other option than "choose most suitable certificate".
Is there a way to see which certificate it is using?
Thanks a lot,
Arnau.
litu
Re: System store certificates
Forget it. I've just installed the new AI version (11.6) and it's solved.
When the "Use certificate from system store" option is enabled, the Advanced Installer will look into the certificate store of the current building user. So, in order to be visible in "Digital Signature" page a certificate should be imported in the certificate store of the current user.
evgeny
I just got a Symantec Code Signing certificate and import it in the certificate store of the current user. But it's still empty in "Use certificate from system store" ComboBox!!!
I also have latest version of Advanced Installer 12.3.1
You can check attached file...
I'm not sure why this happens. Can you please make sure the certificate is of Microsoft Authenticode type? If so, can you please make sure you fully imported the certificate file (also, including its private key)?
evgeny
Solution: The certificate wasn't installed under Administrator account. Reinstalled under Administrator and it works fine now.
I'm glad you sorted things up and let us know the resolution.
NovaES
I hope certificates work well. Remember that the path of your certificate signed follow this order:
Verisign
- Symantec SHA256 Class 3 Code Signing CA
  - Your certificate
Remember that if you are going to use your application in the lower systems to Windows 7, for example Vista, XP ... do not minister it the SHA256 certificate because it is not supported and will give problems.
