PhilB
File removal from property based folder not working
I am attempting to delete a file on uninstall from a property based folder. I've tried setting this up directly and also via the uninstall cleanup wizard. The associated component (installed elsewhere in a regular folder) is removed as expected but I cant get rid of the file!
Running AI 11.0, Win 7 x64
Phil
PhilB
Re: File removal from property based folder not working
Please ignore! Eventually realised that I had to move a CA to be a bit earlier in the sequence than was necessary in the original install. Having moved it, both the install and the uninstall with the file remove operation are working ok.
Phil
Hi Phil,
I'm glad you got this working. Just let us know if any other problem appear.
