ThomasE
Prerequisites exists but aren't found
Hi!
We are having an issue with prerequisites. Some months ago a customer installed our software successfully on his PC (with Windows 8). Our software is based e.g. on .NET Framework 4.0.
Some time ago the customer updated to Windows 8.1. Today he tried to install the latest version of our software. Therefor he started our setup created with Advanced Installer. When starting this it complains that it can't find .NET Framework 4.0 on that machine. This is strange because it's installed there. But it's also strange because the setup also complains that "Windows Installer for Windows XP x86" is missing!! BUT, why is it complaining on a Win 8.1 machine?
Does anybody have an idea why we are facing this problem?
Re: Prerequisites exists but aren't found
I'm not sure why you encounter these problems. However, please note that on Windows 8 and above, the ".NET 4.0" software should not be added as a prerequisite, it should be enabled from "Windows Features" section. You can take a look on the Prerequisite condition problem thread for more details.
This may happen if you have a "Windows Installer for Windows XP x86" prerequisite in your package and it tries to install it, but cannot find it. This means that the install conditions of the prerequisite are not correct.
If you can't fix the problems, can you please send us the .AIP (project file) and a verbose log of the installation to support at advancedinstaller dot com, so we can investigate them?
