kjullion
VS plugin failing after AI v11.6 upgrade
When I launch VS (every time, doesn't matter what project/solution I open) I am seeing a message box that the 'AdvInstVSIntegrationPackage' package did not load correctly.
I have VS Professional 2013.
The ActivityLog.xml file shows this specific error description and info:
CreateInstance failed for package [AdvInstVSIntegrationPackage]
Could not load file or assembly 'file:///C:\Program Files (x86)\Microsoft Visual Studio 12.0\Common7\IDE\Extensions\Caphyon\Advanced Installer 11.5\AdvInstExtensionVSIntegration.vcs12.dll' or one of its dependencies. The system cannot find the file specified.
And this is the message I see in VS when I launch it:
VS plugin error after v11_6 upgrade.png (28.99 KiB) Viewed 5150 times
For me at least, this is not urgent, because I don't yet use the plugin, but I wanted to let you know that I am seeing this message, in case it helps you.
Thanks.
Re: VS plugin failing after AI v11.6 upgrade
Hi Kevin,
Thank you for your feedback. We are aware of this and we'll try to fix it ASAP.
Unfortunately, we are not able to replicate this on our machines. So I'm asking for your help. Can you please help us to track this down?
If are willing to help us, here is what you could do:
1) revert to the 11.5 version of Advanced Installer
2) when installing the 11.6 version of Advanced Installer, please create a verbose log of the installation process
Please tell us if the behavior can be replicated. If Yes, please send us the log file to support at advancedinstaller dot com so we can investigate it.
kjullion
Ok, that is done. The problem does re-occur after downgrading and re-installing. I have sent in the versbose log.
I should note too that it seems to be that when logged on as Administrator the VS plugin error message does not show up, but when logged on as a non-Administrator user that is when I see the error message.
Return to “Feature Requests”
