Alex99
Old version remains in "Programs and Features"after upgrade
Hello, I use Advanced Installer v11.1 build 56565. Radio button "Automaticaly upgrade older product version" is checked. I have one machine where reproduces next scenario:
1) Install previous version
2) Upgrade by current version
3) Both previous and current version are present in "Programs and features". Uninstall previous version.
4) All files are deleted, all uninstall actions have done, but still both previous and current version are present in "Programs and features". Try uninstall previous version, window appears:
5) Press yes. Previous verion is removed from list. But current version still in "Program and features"
Scenario2:
3) Both previous and current version are present in "Programs and features". Uninstall current version.
4) All files are deleted, all uninstall actions have done, but still both previous and current version are present in "Programs and features". Try uninstall current version, window appears:
Why both versions may stay in "Programs and Features" after upgrade?(Radio button "Automaticaly upgrade older product version" is checked, "Allow side by side installs of different product versions" is unchecked) How can I prevent this behaviour?
Re: Old version remains in "Programs and Features"after upgr
Hi Alex,
I'm not sure why you encountered the this behavior.
In order to have a better view about this, can you please send us the .AIP (project file) of the upgraded version and a verbose log of the upgrade process to support at advancedinstaller dot com so we can investigate it? If it contains confidential information you can send us a small test project which reproduce this behavior.
By the way, can you please tell us if the behavior can be replicated on a clean machine (even virtual one)?
Alex99
Thank you for reply, but seems it was a bug of specific build, we cannot reproduce it on another builds.
