eitanElmalam
Update Process
why I get this message ??
attached screen shot.
Thank
Eitan Elmalam
Re: Update Process
Hi Eitan,
This is happening when you are using the same ProductCode because two products with the same ProductCode can not be installed on the same computer. Windows Installer will prevent this with that error.
Please keep in mind that Windows Installer allows you to upgrade an installation in multiple ways. The most important are: Each upgrade method requires a target package and an upgrade package. For the automatic upgrade feature the target and upgraded packages must have different Product Codes and different versions. For a patch, the packages must have the same Product Code and different versions.
Windows Installer will show the error you encountered if:
  • the target and upgraded packages have the same Product Code and the same version, but different contents (for example: you created a package, you installed it, you modified its project, rebuilt the package and tried to install the new package without uninstalling the old one)
  • the target and upgraded images have the same Product Code and different versions (for patches)
