The problem is that the user's in our environment do not have admin rights and it is a giant pain to send IT to everyone's desk to uninstall the old version (not build with A.I.) and then have them reinstall the same software package, but built with A.I.
As you build new versions of an installation package by using Advanced Installer, the new versions should be able to upgrade the older versions (remove them before the installation). Please take a look on the
How do I upgrade an older version of the package? article with related information for hints and guidance.
This way, there will be a single operation that should be done by the IT Administrator, only proceed with the installation of the new version of your installation package.
Any suggestions on how to upgrade the current install to an Advanced Installer package, without requiring admin rights? Or is this just not possible?
Removing and installing a per-machine package will require administrative privileges.
I failed to mention that if the user does not currently have the software installed (package built not with A.I.) then we would require admin rights to install. Only the user's who currently have the software installed (not build with A.I.) would we want to switch over to the package built with A.I. without requiring admin rights.
As I can see you want to be able to install your updates without elevation. Advanced Installer can handle installation without elevation but the first installation package will require administrative privileges.
So, in the Advanced Installer project, you need to configure the
Updater as it is described in the
Handle updates without elevation article and further updates will not require any elevation because the
support service which will handle updates without elevation is installed.
The installation of this service prepares the package to support the installation of updates without elevation on restricted user accounts.
