VAlch
Radio buttons should looks like chekbox
May be a strange question, but
I need a radiobuttons group that will looks like checkboxes (square instead round).
So the question is, is it possible (and how) to create some event the will be unchek CheckBox_2 if CheckBox_1 is checked (and reverse - uncheck CheckBox_1 if CheckBox_2 checked).
Thanks.
Re: Radio buttons should looks like chekbox
In order to achieve this, you can select each checkbox and create a "Set installer property" published event that sets the property related to the other checkbox to empty, as in the example below:
  • On "CheckBox 1":
    Property: CHECKBOX_2_PROP
    Value: {}
    On "CheckBox 2":
    Property: CHECKBOX_1_PROP
    Value: {}
Let us know if this helped.
VAlch
Yes, that is what I need! Thank you!
You're welcome. I'm glad I could help.
