vidur
Conditional Windows server installer
Im trying to build an installer which should not install if the OS is win Server. Unless we select an option to make it a server installer.
Here is what i have done:
Installer proprty - "SERVERINSTALLER" (0 - no and 1 - YES)
Only if this property is 1 i want it to install on win server .
in Launch condition i have put the following condition:
(Not Installed) AND  (NOT (MsiNTProductType <> 1 OR VersionNT = 502  OR VersionNT64 = 502) OR SERVERINSTALLER ="1")
Will this work?
or is there an easier way of doing this?
Thanks for your reply
Re: Conditional Windows server installer
You can easily configure your setup project not to install on Windows Server machines by using only the "MsiNTProductType" property. For example you can use a custom launch condition like this:
  • Condition: MsiNTProductType = 1
    Description: The setup package cannot be installed on Windows Server machines.
Let us know if this helped, otherwise please give us more details about what you are trying to accomplish.
vidur
thanks for your reply. It worked
You're welcome.
