VAlch
Exit from Installaer
Hello! I need to exit from installer while installation without user interaction.
For example, before starting I run vbs script and calculate day of week, installer should be started only on weekend. So if Friday is today, I want to show alert box (or custom form from Advanced Installer: Notification form and then form with exit button) and exit from setup. IF it's a weekend, the installer will started.
Is any condition, that I can use to manipulate installer start? Condition can be any, I just need a tool to manipulate start process.
Thanks in advance.
mihai.petcu
Re: Exit from Installaer
Look into Custom Launch Conditions tab from Launch Conditions page. What you type in the "Description" field of the custom action will appear in the alert box.
Also, be sure to schedule the .VBS custom action before LaunchConditions standard action and share it in both the Wizard Dialogs and Install Execute Stages to cover silent installations as well.
VAlch
Thanks a lot, this solution helped for me to fix a problem.
Vasiliy
