Meera
Advanced installer License issue
Advanced Installer seem to lose their license every once in a while and we got a registration wizard saying "Advanced installer has detected an invalid license....."(please see attachment). And We need to reenter the license key again to register it. We have installed and registered advanced installer in two build VMs and it happens in those two VMs too. How can we avoid this window? Is it happens because of an update?
We need to avoid it because this causes the automated build to create setups with trial versions since it loses it license automatically.Please provide us a solution to avoid this in future?
Thanks & Regards
Meera
advanced installer.png (44.9 KiB) Viewed 1946 times
Re: Advanced installer License issue
Hi Meera and welcome to Advanced Installer forums.
This may happen if the Computer ID of the build Virtual Machines changes. For example, the Computer ID can be changed if you use a virtual machine that chooses on which OS configuration to run at boot time.
You can send us an email to support at advancedinstaller dot com with your License Key, so we can send you a special license file that you can test.
