BeSeWe
Tomcat with -XX:PermSize=128m Paramter
I'm currently building a Installer for my Tomcat Application. And I have now the problem, that the installation works fine. But when I start the app I get the following error: java.lang.OutOfMemoryError: PermGen space
Therfore I search for a possibilty to add the folloing parameter -XX:PermSize=128m to my service.
When I add this parameter to the catailina.bat and start it manually it works fine.
Thanks in advance.
Benjamin
Re: Tomcat with -XX:PermSize=128m Paramter
Hello Benjamin and welcome to Advanced Installer forums,
In order to add the related parameter to your Tomcat service you can use a BAT file with proper command lines. For, example you can add the BAT file in "Files and Folders" page and then launch it using a "Launch file" predefined custom action scheduled in "Custom Actions" page after "Install Execution Stage -> Add Resources" action group as deferred.
Also, please take a look on the "Installing and Updating Services" articles which should be useful for you.
Let us know if this helped, otherwise please give us more details about what you are trying to achieve.
