oxhey
Prerequisite File Size
In my main installer the user can chose to download modules . These are post install prerequisite.
Is there an option to update the file size when one of these modules is selected .
At this point i have just put the file size next to the name of the module .
Re: Prerequisite File Size
I'm afraid I don't fully understand what is your scenario. Can you give us more details about your scenario (maybe exemplify)?
oxhey
So My main installer is a web installer . It has the main application which is 60 mb . It also has some prerequisite options (downloaded from the web) that the user can select to install . These are modules for the main application.
When the user is at the screen to choose what to install , it will show the size of the main application . Is there a way to do this for the prerequisite as well , even if it means me manually entering the file size to be displayed.
To achieve this, you can go in the "Organization" page, select the feature related to your prerequisites, check the "Reserve additional disc space for this component" option and in the "Run Local" field write the size of your prerequisite.
