jeremy.vignelles
[Trial&Registration DLL]Use the trial DLL in a service
I'm trying to integrate the Trial&Registration DLL to a windows service .NET application, but I'm facing a problem.
I made a test console application in order to illustrate what I'm saying.
using System;
using System.Runtime.InteropServices;
namespace TestLicensing {
    class Program {
        private const string kLibraryKey = "F1059AF815057E72D12FF5B0B852E699695505F98FE0199C769C6941B963A74AC97904AEC102";
        [DllImport("Trial.dll", EntryPoint = "ReadSettingsRetStr", CharSet = CharSet.Ansi)]
        static extern uint InitTrial(String aKeyCode, IntPtr aHWnd);
        static void Main(string[] args) {
            var result = InitTrial(kLibraryKey, IntPtr.Zero);
            Console.WriteLine(result);
            Console.ReadKey();
See the attached file for the error message.
I suspect the IntPtr.Zero to be the cause of the problem. Is there a way to call the method without having a window in my program?
Regards
Console application screenshot
Re: [Trial&Registration DLL]Use the trial DLL in a service
To hide our trial dialog you can set the "Display Frequency percent" field, from "Licensing page -> Display tab" of your added trial, to 0 (zero). Also, please take a look on our "Advanced Installer using my custom form for trial.dll" thread which should be useful for your.
Let us know if this helped.
jeremy.vignelles
I tried again today and it now seems to work...
Maybe I did not compile again the project.
Thanks for your answer :)
Regards
