Andrey
Uninstallation prompts UAC after silent PerUser installation
Hi AI-team,
I've attached uninstall_cu.aip project. It has only 2 changes against default project:
- Installation type: Per-machine if user is administrator, per-user otherwise.
- In Dialogs added: InstallType Dlg.
The msi could be easily installed silently Per User from command line without prompting UAC window:
msiexec /i <msi> /qn ALLUSERS=""
But when I'm trying to uninstall with full UI, UAC is prompting:
msiexec /x <msi>/qf
Why does it happens? I've expected that PerUser installation shouldn't require admin rights to uninstall. What is the proper way to install msi silently for current user?
This is very important scenario, because if application is distributed silently by Group Policies it couldn't be updated in background silently.
2 strange facts:
Everything works fine if uninstall silently:
msiexec /x <msi>/qn
Also the MSI uninstalls correctly without prompting UAC if it had been installed with full UI.
Kind regards,
Andrey
u_cu.aip
(11.4 KiB) Downloaded 515 times
Re: Uninstallation prompts UAC after silent PerUser installa
Hi Andrey,
I've tested your scenario using the provided sample and everything worked as expected. When performing a Per-User installation, I didn't get any UAC prompt on install or uninstall.
Of course, during a Per-Machine installation I got the UAC prompt during install and uninstall process.
Can you please try to test this on multiple machine and see if the behavior still persist?
Andrey
Hi Dan,
I have reproduced the problem on virtual machine (Windows 8 En x64).
Here is simple batch script:
msiexec /i %1 /qn ALLUSERS=""
msiexec /x %1
Andrey
Hi Andrey,
In order to perform a Per-user installation, you need to pass the following properties with the following values through the command-line:
  • ALLUSERS = 2
  • MSIINSTALLPERUSER = 1
So your command line statement should look something like that:
msiexec.exe /i "Your Application.msi" /qb ALLUSERS=2 MSIINSTALLPERUSER=1
Using this command line a Per-User installation type will be made.
Please take a look on the ALLUSERS property article and MSIINSTALLPERUSER property article for a better view about this.
Andrey
Thank a lot Dan!
You really helped me.
I have checked this solution on win 7 and win8. Hope that it also work fine on win xp.
best regards,
Andrey
You're welcome Andrey,
Andrey
I have tested on xp, so as written in article this parameters will not work.
Correct combination for Windows 7 and higher:
Current User: ALLUSERS=2 MSIINSTALLPERUSER=1
Local Machine: ALLUSERS=2 MSIINSTALLPERUSER=""
For Vista and lower:
Current User: ALLUSERS=""
Local Machine: ALLUSERS=1
Hope this can be helpful for those who develop installers.
Andrey
