radug
error in advancedinstaller 11.6.2
I think I found an error in the last version of AdvancedInstaller:
Platform: Win7 / 64-bit
Software: Office 2010/VS2012 prof./VS2013 Community Ed.
Project type: Mixed 32/64bit installation package
Steps to reproduce the behavior:
Add 2 exe files (1 for 32bit and one for 64bit) and the shortcuts to these files.
Note: The 32bit version was not placed in a subfolder as initially proposed by AdvancedInstaller!
Modify (rename) one of the files in the window (Files,Folders and Shortcuts) and try to move the cursor to the other file. BOOM!
Or in some cases no BOOM but only the 'Property' can no longer be accessed (via Menu or Right-mouse click).
Attached is a screenshot with the error.
Question: I found this trying to rename the files 'test_32bit.exe' respectively 'test_64bit.exe' to 'test.exe' at installation time.
This seems not to be possible. Am I right?
Radu G.
radug
Re: error in advancedinstaller 11.6.2
and here:
radug
it seems to work correctly in 11.6.3!
you, people, are very quick! :D
just ignore!
Hello Radu,
I'm glad you got everything working.
I've tested the scenario using AI 11.6.2 but I cannot replicate the behavior. I'm not sure why this happened. If you can replicate again the behavior, then you can try to isolate it in a buildable sample (.aip + its referenced files) which replicates consistently and send it us to so we can further investigate this.
