dexter_v
Reverting back to old version of the application
I would like to know, if there is any feature available in Advanced Installer, which will allow a user to revert back to the previous version of the installed application.
For example: I create an installer (version 1), the user installs it on his system. Now I create another installer (version 2) send this as an update to the user. The user installs the version 2 on his system. Now for some reason he does not like version 2, is there any feature in advanced installer which I can package in the installer(version 2), so that the user can revert back to version 1.
Is this feature available in trial version so that I can try? If yes how do I do it.
Re: Reverting back to old version of the application
Unfortunately, neither Advanced Installer nor Windows Installer have built-in support for downgrading installation scenario. As a workaround you can configure your product to allow side by side installation. In this way different versions of your product can be installed side by side.
However, as another workaround, you can use the approach exposed in our "uninstalling version if trying to install older version", but keep in mind this is not a recommended scenario.
dexter_v
Hi Daniel,
Thanks for your prompt reply.
I'm trying out the side by side installation, I was able to create an upgrade for the version 1 with side by side installation enabled, I created version 2 with the side by side installation enabled.
I've changed the production Name, Production version, Shortcut of the exe. I can see both the shortcuts on my screen.
However, When I'm trying to install the version 2, The installation wizard is not giving me the option to uninstall the old version and keep side by side installation. Like you have provided in the advanced installer setup.
For example: I should get the options mentioned in the below image
How do i do this?
Just go to "Dialogs" page and using the "Add Dialog..." context menu option add the "UpgradeDlg" dialog.
dexter_v
Hi Daniel
Thanks, it worked :)
You're welcome.
