dwagner1
Duplicate application in Add/Remove programs
Hello All!!
I'm brand new to Advanced Installer and very excited to start using it...but have an issue...(I'm sure user error), but trying to get past it and didn't see anything on the forum...
Here is what I'm doing...
I'm using the MSI from EXE(s) project type and following these steps and I'm getting duplicate names in the Add/Remove programs list:
I'm entering the details about your project
Next
I'm leaving the set project and package paths to the default
Next
Configure packages and select from disk and select the setup.exe and click Open and click Add folder and select the other files/folders that go with the install as the Additional Files and click OK
Next
Check the box for "Show MSI information in Programs and Features (Add/Remove Programs) applet in Control Panel
Next
Unselect Build the project now
Finish
Click Media and Click MSI Build - MSI setup file
Build
Then select the .msi that it created in the output folder
Copy it to a VM and run it, it installs fine, but shows duplicate names in the Add/Remove programs
Thanks in advance!
Darin
Advanced Installer Add_Remove duplicates.jpg (106.75 KiB) Viewed 1781 times
Re: Duplicate application in Add/Remove programs
Hi Darin and welcome to Advanced Installer forums,
I'm not sure why you encountered the this behavior.
