LaughingJohn
Change AI install path to not include version
Every time I install a new version of Advanced Installer it breaks my build which is real pain. I then have to go through multiple .aiproj files and change the path. Please can you remove the version from the install path.
Re: Change AI install path to not include version
Hi John,
Since multiple versions of Advanced Installer can be installed side by side, several rules must be fulfilled.
The most important is that the install locations, registry entries should differ from one version to another. If they are not different, the present items will be overwritten when a new version is installed. Here's the Upgrades article.
This is way we are using the ProductVersion in the installation path.
Return to “Feature Requests”
