cibus
Problems making MSI wrapper
Hey
This is my first project and I need to make a MSI file out of the TerraExplorer plugin.
To install this .EXE file silently I have to do the following;
1. Place the standard TerraExplorer installer in a temp folder.
2. Create a text file called “setup.iss” next to the installer that includes the following text:
[{8E18A29B-45AB-4D37-9CB9-78D3FB068811}-DlgOrder]
Count=0
3. Call:
Setup.exe /s /f1[FullPath2issFile] /hide_progress /V”Silent=1”
Done this and tried running the exe-file manually, ALL OK.
Now to wrap this with Advanced Installer....
Tried using the guide on http://www.advancedinstaller.com/user-g ... r-exe.html without any luck.
I made a batch-file called terra.bat;
SkylineGlobeSetup /s /f1[setup.iss] /hide_progress /V"Silent=1"
When the installer starts (and exists?) nothing happens... :(
Added a screenshot to show my settings.
Any help would be appreciated...
Re: Problems making MSI wrapper
Most likely, you have added your custom action without sequence, this is why your custom action is not executed. Without any event as trigger, the custom action will never be executed.
However, you need to add your custom action as a custom action with sequence, so it be displayed in the list.
Please take a look on the Add custom action with sequence article which may be useful to you.
cibus
Didnt get it to work.
I just added it as custom with sequence. But it doesnt ask about working directory. I guess its all from the same temporary folder?
Anyways, it fails saying something is wrong with the MSI file.
I'm not sure why you encountered the this behavior.
cibus
I have tried many times now.
I just tried to simplify it. Just adding an EXE file and run it.
But I get the same error.
I will send the files made with a new project doing the same thing.
