jason.morris
Updater unable to download file with credentials
I am trying to set up the Advanced Installer Updater. I have successfully created the updates.txt file and the upgraded version of my product. The server from which the updates.txt and upgraded product msi file are being checked needs credentials to be embedded within the URL. The updates.txt file is obviously being read correctly as the update available box is shown when checking for updates from the application (without the need to enter any credentials) however when it comes to download the update file it asks for credentials despite the fact they are included in the updates URL and within the updates.txt file.
The following is the updates.txt file:
;aiu;
[Perception DQ Server Version 1.1.0.0]
Name=Perception DQ - Server
ProductVersion=1.1.0.0
URL=http:username:password@//www.mysite.co.uk/myapplication/RunMeToUpgradeServer.msi
Size=47108096
MD5=c178800b7c60feaf7fed804a273bb349
ServerFileName=RunMeToUpgradeServer.msi
Flags=Critical
FilePath=[APPDIR]PerceptionDQ.exe
Version=1.1.0.0
Description=Upgrade from Version 1.0.0.0 to Version 1.1.0.0
If I enter the credentials manually when prompted the update is downloaded and installed.
I am using version 11.6.3 of Advanced Installer and IE version 11.
All seems to be fine but it is not working, any help will be gratefully received.
Re: Updater unable to download file with credentials
In the URL that you posted, the username and password are placed between the ":" and "//" characters, but they should be written after the double slash, as in the example below:
http://<username>:<pwd>@www.mysite.co.uk/myapplication/RunMeToUpgradeServer.msi
Can you correct this and see if it works?
jason.morris
Thank you for the reply. It was just a typo error when posting the issue on the forum it is actually as you suggest within the updates.txt file:
URL=http://username:password@www.mysite.co. ... Server.msi
I still am asked for credentials when trying to download the update file.
Jason
Hi Jason,
I'm not sure why this problem appears. Can you send us a sample MSI package that reproduces the issue to support at advancedinstaller dot com, so we can test it and try to investigate the problem?
jason.morris
Eusebiu,
I will put together a small MSI to test, as the application is 42mb zipped. I am however confused as to the reason for requesting the MSI package, as the package downloads and installs correctly once the credentials are entered.
The updates.txt file is accessed (read) using the same credentials in the same format, this is working fine when the application checks for updates. The correct update information is retrieved and bug fix/enhancement information is also displayed in the updates available window, it is only upon clicking to continue does it request credentials.
regards,
Jason
Hi Jason,
Sorry because I didn't explain correctly my request, but it is not the installation of the MSI that I want to test. I want to test the updater connection to one of your test servers, if you can configure one in the MSI package.
jason.morris
Hi Eusebiu,
I have just emailed a test project with test credentials to access our server. Thanks.
Jason
jason.morris
This issue is now resolved.
Thank you for your help.
You're welcome Jason. I'm glad you got this working.
PavelRakowski
RESOLVED? So wtf is solution? I have same issue, why you not post the issue here but in your EMAILS?
I go to buy EnigmaProtector, as you support = shit.
The solution described in the second post of this thread is correct and it worked for jason.morris. His problem was that he used incorrect credentials (username and password) in the URL and they were not accepted by the server, but when the correct credentials were used, everything worked.
PavelRakowski
Ok thanks but anyways is there a way to protect updates pass and user?
I just entered in config.aiu this url:
http://user:pass123@www.website.com/upd ... config.aiu
and then when I lunch Updater.exe manually from installed path, then open TELERIK Fiddler and check the AUTH I get this:
No Proxy-Authorization Header is present.
Authorization Header is present: Basic VnNUYkJ1OUtNNDVkRGVtU0FhVmJuQmVyRGRzc3BsaTU0
Decoded Username:Password= user:pass123
SO for what is this useful if any HACKER can get the Setup and see the protected password? hmm..?? Dont you think it is really useless your soft??
PROBLEM 2:
Also I set this correctly and then lunch app, it use autoupdater, then it not filled user AND pass automatically but popup form opened and I had to enter manually credentials, so another bug, or ???
SO SOME FIX to this both issues of mine?
Please note that the "HTTP" protocol is not secure and that is why the username and the password are not encrypted. In order for the information to be encrypted you need to use the "HTTPS" protocol which is a secure protocol.
I'm not sure why this happens. Can you test that URL in a web browser and see if it works there? Otherwise it may be a problem with the configuration of your server.
rileydog
Hello, I know this is a very old post; however, it addresses what I need.
I have also looked here: viewtopic.php?t=32426
As i understand the solution, it is to included the user/pwd in the url. I understand that.
My Question: How do i make that happen with AI (need new initials for your product ") )? i don't see anywhere in the AI screens to enter the user/pwd, so how would AI attach to the url?
I noticed in the product comparision table, i found this:
FEATURE FEATURE DESCRIPTION
HTTP authentication, HTTPS Downloading over HTTPS is supported, as well as HTTP authentication which prompts for a user and password.
Note: this feature was only for Architect and Enterprise. I have "Professional" Does this mean i can't download files to support what i want to do as described above.
Wayne Glover
Hello Wayne,
As you've seen, the password and username can be sent via the URL:
The URL can be found in the "Updates configuration project", undet the "Properties" tab.
