viswammamilla
How to apply permissions to Main Installation
This is viswam. Iam trying to do a msi setup from advanced installer.
Everything is good and working fine.
But i have a small problem in installation.
All Prerequisites installing well. After prerequisites, am facing a problem in main installation for some users only. Iam getting an error like below.
"An error occurred while applying security settings. Users is not a valid user or groups. This could be a problem with the package or a problem connecting to a domain controller on the network. Check your connections and try again".
In "Files and Folders", i given permissions for "Application Folder" like below
Domain = Empty
Username = Users
Permissions = Full Control
Checked Apply permissions to all sub folders.
I want to install the setup file in any user and want to give full permissions to the folder am creating in the program files.
Please help me how to do this.
Thanks in Advance,
Viswam Mamilla
Re: How to apply permissions to Main Installation
Hello Viswam,
This may happen if you are installing the setup package on a target machine having a different system language than English. In this case, you should use the [GRP_USERS] property reference in the "Username" field. Please take a look on our "How do I localize user or group accounts?" faq.
If this is of no help to you please please send us the .AIP (project file) and a verbose log of the installation to support at advancedinstaller dot com so we can investigate them.
viswammamilla
Hello
Daniel,
I tried with Everyone in the username field,
Its working with that. If i face similar issue then i will try GRP_USERS. Thank you very much for your support.
Thanks & Regards,
Viswam Mamilla
You're always welcome Viswam. I'm glad you got this working.
