XiaoFaye
Updater reports an error even the update has been installed
Hi
I'm using the Advanced Installer updater to update my program. The update file is a self-extract exe file, which will be run by the updater.
however, when the update file has been run successfully, the updater still reports an error. Could you please help me out?
Re: Updater reports an error even the update has been instal
You can take a look on the Why do I receive the "Some of the updates failed to install properly" message FAQ which describes this problem.
XiaoFaye
Eusebiu wrote:Hi,
I don't need to check if the update has been installed successfully, I would like the updater always gives me a successful message no matter how the update file runs.
Would I be able to do that?
We do not have support for this yet, but it is already on our TODO list and it will be available in a future version of Advanced Installer.
The option "to skip the updates installation check after the updates are installed" has been added in version 12.0 of Advanced Installer released on April 2nd, 2015.
For this, you can enable the Do not try to detect if the update was installed option from the Update Properties" tab.
