lidds
Problem with installing and starting service...
I am using AdvancedInstaller to deploy and install my application, and I cannot figure out why the ElecKey service will not start using the installer. As you can see from the below screen shot I have defined the arguments required to install the service i.e.:
/SERVICE “/INSTALL Ticodi Licensing Manager”
[See attached]
And if I deploy the application without AdvancedInstaller trying to install the service and run a .bat file that contains the following:
cd C:\Program Files (x86)\Ticodi\Ticodi License Server 1.3\Server
NKLS40EK /SERVICE "/INSTALL Ticodi Licensing Manager"
Pause
Then it will install and start the service.
AdvancedInstaller will install the service, but when I go to start the service it will not start. I appreciate that this is trying to install a third party service, and I have sent the same email to the company in question, however I thought I would still post it here to make sure I am not doing something wrong?
Do you have any ideas?
Best Regards
Simon Liddicott
http://www.ticodi.com
Tel: 0800 0025163 (UK Only)
Tel: +44 (0)207 1013139
Re: Problem with installing and starting service...
Hello Simon,
You can try the following and see if this helps you:
1. remove the /SERVICE “/INSTALL Ticodi Licensing Manager” command from the "Arguments" field
or
2. uncheck the "Start" event on install set in your service's control operation
If this is still of no help to you, then please send us the .AIP (project file) and a verbose log of the installation to support at advancedinstaller dot com so we can investigate them.
