Better design the checkboxes-make them easier to use:
Instead of just having a value when its checked and no value when its not checked, set the value to true or 1 or -1 when checked and 0 or false when not checked.
I ask this as I just went through a confusing process, in order to allow me to set a registry value.When a checkbox is not checked, no value is stored. I found the workaround by setting the property using the Publish Events (http://www.advancedinstaller.com/forums ... php?t=2908) but this was still not a complete solution.
The difference between the Value and Default Value is confusing and the help files do little to explain the functionality.
