MarwaAhmad
Old version:This action is only valid for products installed
I have advanced installer 11.2.1, I use in the updater "Uninstall old version first then install new version". The new version replaced the old version successfully but I saw that all the old versions were kept in the "programs and features"; windows OS. When trying to uninstall these old versions i got: "This action is only valid for products currently installed" attached a screen shot.
Would you please advice? as this issue in all customers using our product.
Re: Old version:This action is only valid for products insta
As I can see in your screenshot, you have changed only the forth field of the version of your application. However, please keep in mind that Windows Installer ignores that field and does not consider it as a new version.
Changing only that field can lead to problems like yours. In order to remove those empty entries from the "Programs and features" window, you can go to the following registry paths and remove the registry keys that have the name or the Product Code of your application:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall
MarwaAhmad
Thank you Eusebiu, do you have any idea how could i remove the old versions in the registry using AdvancedInstaller?
In order to remove them from Advanced Installer, you can go in the "Registry" page, create all those registry keys with their paths, then for each registry key that you want to remove, go to "Properties -> Operations" tab and check the "Remove this key with all its values and subkeys" option.
MarwaAhmad
Thank you Eusebiu for your support, your suggestion solved my issue.
You're welcome. I'm glad you solved the problem.
