imphero
Attaching custom actions to buttons
Hey guys. Running Advanced Installer 11.6.3 here.
I've been trying to figure out how to attach custom actions to buttons for a while now but I just cannot figure it out. I've searched extensively through the documentation and have come to the conclusion that I am either missing something or experiencing a bug.
The documentation gives the impression that if I select a button via the dialog editor, then create a new 'Published Event', then select 'Execute custom action' as the control event I should be able to see my custom actions in the 'Arguments' drop down combo box.
Mine is currently empty so I am wondering if there is something I need to do to make my custom actions available here?
Proof that I have at least one custom action defined:
No custom actions listed where I am led to believe they should be:
Could someone please shed some light on this please?
Re: Attaching custom actions to buttons
Please note that in order to be able to use a custom action on a button, you need to add it "without sequence" as displayed in the attached image.
Let us know if this helped.
Custom Action Without Sequence.png (39.65 KiB) Viewed 3527 times
imphero
Excellent thank you for your quick and helpful response. I was double clicking the events to add them and didn't even notice the 'with sequence' and 'without sequence' buttons.
But I am all sorted now so thanks again Eusebiu.
Just let us know if you have any other question.
