BertUschold
Excel does not open properly at end of installation
I have created an msi file to install Excel and some other files on to a users computer. The Excel file has macros enabled and the other files include 3rd party software to license protect the Excel file. The ExitDialog is set up to have the show Readme file and Launch Application checked by default.
When running the file on my computer, Windows 7, 64 bit, Excel opens but not the required file. This same problem occurs on another computer whose specs I believe are the same.
I realize this is not a full description of the setup , but I am a novice user at best. Hopefully there is enough here to suggest a solution or at least know what additional information someone would need to debug it. Finally, it is the free version of Advanced Installer, version 11.7 but the problem also occurred when using 11.4.
Thanks.
Re: Excel does not open properly at end of installation
In order to have a clear view of your installation scenario can you please send us the .aip (project file) to support at advancedinstaller dot com so we can check its settings? Also, it would be useful if you could exemplify a bit or send us a screenshot with what you are expecting to be opened when the application is launched at the end of installation.
