AzubiRA
Nothing right in additional builds? No TabHost, no Bitmaps.
Alright I have a follow-up problem which seems to be tied to the first one over here:
http://www.advancedinstaller.com/forums ... =2&t=29838
tl;dr: VBScript-manipulated property would show correctly in a Webinstaller but wrong in a different build.
Next 2 problems:
1.
Tab Host working fine in Webinstaller but not be shown in any other build. In the ConfigureDlg the CustomizePage is just replaced by a string: 'TabHost'.
2.
DialogBitmap and BannerBitmap are back to AI-default in the other builds and only correct in my first build, Webinstaller.
Maybe there are even more problems with the additional builds which I haven't found yet.
So, what is the problem with adding builds? Shouldn't I be expecting them to work properly?
Re: Nothing right in additional builds? No TabHost, no Bitma
Please note that the Tab Host control require the Enhanced User Interface. If this feature is disabled, your controls will not be properly displayed.
Please note that these images can be set per build. Tat means each build can use different images. Please see the attached image for your reference:
By the way, if you have multiple builds defined and then try to change the DialogBitmap or BannerBitmap , you will get a prompt, asking if you want to set these images for all builds. Did you get this prompt? See the attached image:
AzubiRA
You guys are great!
All your proposals worked like a charm.
It would be helpful btw. to have some popup when placing a TabHost to say it works only in an EXE, or other hints of the like which instantly point to counterdependencies some newbie like myself would overlook. You know, some tutorial mode.
Anyway, thanks a ton for your quick and concise reply.
You're always welcome,
Thank you for your kind words.
It would be helpful btw. to have some popup when placing a TabHost to say it works only in an EXE, or other hints [..]
There should be a prompt when adding the TabHost on a dialog in a .MSI package type as you can see below:
If you want to learn more about Advanced Installer check below for pointers on the most relevant content. In our User Guide you can read: The entire documentation can be found in our online user-guide or by pressing F1 inside Advanced Installer.
